Programming Your ECU
The programming process takes approximately 90 seconds.  During this time, it is important not to interrupt the programming process by unplugging a cable or cancelling the upload.
If the programming process is interrupted or fails, the ECU will be left in recovery mode.  In this case the ECU will not run the engine, but it is still possible to re-program the ECU with FlashPro.
