Table indexes |
For more effective tuning, it is possible to re-index some tables. This is useful in order to get more resolution around VTEC point, or to expand the rpm range of a table.
When the index for a table is altered, internally all tables using the same index must be updated. Thus for some calibrations it is not possible to alter the index values if every single instance of the index in use has not been identified.
For information on how to change the index values see changing table indexes. |
