TL 2007-2008
TL
2007-2008
USA
RDB-A01 to RDB-A05
RDA-A81 to RDA-A85
RDB-A51 to RDB-A56
RDB-A11 to RDB-A12
RDB-A61 to RDBA-65
TL Americas
General
Forced induction support
Expanded tables
Live tuning
Wideband lambda input
Traction control input
Fuel
MAP based tuning
Injector size & fuel pressure parameters
Injector voltage compensation
MAP fuel tables
Full load compensation tables
Overall fuel trim
Cranking fuel trim
Cranking fuel table
Cylinder fuel trim
Air temperature fuel trim
Coolant temperature fuel trim
Ignition
Ignition tables
Tip in retard compensation
Cylinder ignition trim
Air temperature ignition trim
Coolant temperature ignition trim
VTEC/VTC
VTEC rpm window
VTEC pressure window
VTEC conditions
VTEC oil pressure input enable/disable
Secondary intake runner settings
Closed loop
Short, medium and long term trim limits
Full load determination tables (MAP / TPS)
Wideband current to lambda conversion table
Target lambda
Knock
Knock ignition limit
Knock sensitivity table
Knock retard table
Rev limits
Overall rev limiter
Launch rev limiter
Speed limiter
Boost cut
Sensors
MAP sensor selection
Idle
Idle speed tables
After start idle speed table
Throttle
Target throttle plate table
Overrun throttle closure (rev hang)
Overrun injector control
Throttle flow vs opening
Misc
Various DTC enable/disable
Cooling fan temperature
Calibrations
Starting calibrations for NA, forced induction & larger injectors.
