DDE Server |
SManager can function as a DDE server for simple transfer for data from SManager. DDE (dynamic data exchange) is a technology that allows inter-process data transfer between two applications. It is useful for extracting datalogging values from SManager for further analysis.
Server: SManager
Topic: Calibration Item: Name Returns the calibration name if a calibration is loaded. Excel example: =SManager|Calibration!Name
Topic: Datalog Item: FrameCount Returns the number of datalogging frames. This is updated dynamically when datalogging. Excel example: =SManager|Datalog!FrameCount
Topic: Sensors Item: Count Returns the number of sensors. Excel example: =SManager|Sensors!Count
Item: Names Returns an array of sensor names. Excel example: =SManager|Sensors!Names
Item: Values Returns an array of sensor values. Excel example: =SManager|Sensors!Values
Item: Units Returns an array of the sensor units. Excel example: =SManager|Sensors!Units
Item: sensor name Returns an individual sensor value. Sensor names with space should be placed inside single quotation marks. Excel example: =SManager|Sensors!'Knock Retard'
Note for Excel to display arrays the Ctrl-Shift-Enter method is used to populate a selection with a formula.
Windows Example |
