Fuel Injector Parameters |
This tab contains settings relating to the injector size.
Injector Size
Changing the injector size will automatically compensate the fuel tables for the rating of the injector (but not for the specific characteristics of the injector). Also the cranking fuel and throttle tip in fuel are compensated based on the injector size. Most stock Honda B & H series engines use 240 cc/minute injectors; most F & H series engines use 310 cc/minute injectors. For non-standard fuel pressure use the overall fuel trim to compensate.
Injectors have a minimum pulse width before any fuel is injected, known as the injector 'dead time'. This varies by voltage and may be adjusted for different injector characteristics.
Also see Staged Fuel Injection |
