Civic Si
2006
USA
No VSA
RRB-A04 to RRB-A05
RRB-305
Civic Si Americas
2007-2011
USA
VSA
RRB-A060 to RRB-A140
Civic Si Americas
2007-2011
Mexico
RRB-X110 to RRB-X120
Civic Si Americas
2007-2011
Central America
RRB-K010 to RRB-K020
Civic Si Americas
2007-2011
South America
RRD-M110 to RRD-M120
Civic Si Americas
2007-2011
South America
RRD-M210 to RRD-M220
Civic Si Americas
2007-2011
South America
RRD-P110 to RRD-P120
Civic Si Americas
2007-2011
South America
RRD-P210
Civic Si Americas
General
• | Forced induction support |
Fuel
• | AFM, MAP or hybrid AFM/MAP tuning |
• | Injector size & fuel pressure parameters |
• | Injector voltage compensation |
• | Full load compensation tables |
• | Air temperature fuel trim |
• | Coolant temperature fuel trim |
Ignition
• | Tip in retard compensation |
• | Gear ignition compensation |
• | Air temperature ignition trim |
• | Coolant temperature ignition trim |
VTEC/VTC
• | VTEC oil pressure input enable/disable |
Closed loop
• | Short, medium and long term trim limits |
• | Full load determination tables (MAP / TPS) |
• | Wideband current to lambda conversion table |
Knock
Rev limits
Sensors
Idle
• | After start idle speed table |
Throttle
• | Target throttle plate table |
• | Overrun throttle closure (rev hang) |
Misc
• | Various sensor enable/disable |
• | Various DTC enable/disable |
• | Cooling fan sensor selection |
1. Engine oil life not functional with the race calibration. When switching from a race to normal calibration the Maintenance Minder will need to be reset.
2. Trip meter not functional with the race calibration.
