Civic Si 2012-2015
Civic Si
2012-2015
USA
RX0-A01 to RX0-A05
RX0-A12 to RX0-A14
RX0-A21
Civic Si/ILX Americas
2012-2015
Americas
RX0-X01 to RX0-X05
RX0-K01 to RX0-K05
ILX
2013+
USA
R9B-A01 to R9B-A05
General
Forced induction support
Expanded tables
Live tuning
Wideband lambda input
Boost control output
Ethanol content input
Traction control input
Fuel
AFM, MAP or hybrid AFM/MAP tuning
Injector size & fuel pressure parameters
Injector voltage compensation
MAP fuel tables
Full load compensation tables
Overall fuel trim
Cranking fuel trim
Cranking fuel table
Cylinder fuel trim
Air temperature fuel trim
Coolant temperature fuel trim
Ignition
Ignition tables
Tip in retard compensation
Gear ignition compensation
Cylinder ignition trim
Air temperature ignition trim
Coolant temperature ignition trim
Coolant temperature ignition retard
VTEC/VTC
VTEC rpm window
VTEC pressure window
VTEC conditions
VTEC oil pressure input enable/disable
Cam angle tables
VTC PID parameters
Closed loop
Short, medium and long term trim limits
Full load determination tables (MAP / TPS)
Wideband current to lambda conversion table
Target lambda
Knock
Knock ignition limit
Knock retard table
Rev limits
Overall rev limiter
Launch rev limiter
Speed limiter
Boost cut
Full throttle shift
Anti-lag
Sensors
AFM calibration
MAP sensor selection
Idle
Idle speed tables
After start idle speed table
Throttle
Target throttle plate table
Overrun throttle closure (rev hang)
Misc
Various sensor enable/disable
Various DTC enable/disable
Cooling fan temperature
