To unlock the FlashPro from the current vehicle select Unlock from Vehicle from the Online menu.
The following is required before the FlashPro can be unlocked from the current vehicle:
• | The ECU must be the same ECU as the FlashPro was locked to. |
• | The ECU must be returned to stock using the Online menu option. |
• | An internet connection must be available so that it can be verified that the FlashPro is not stolen or subject to fraud before unlocking. |
• | If you return to stock using the FlashPro without a laptop, but sure to key off at the end of the upload (there is no laptop to tell you to do so) and then power the ignition back on for 10 seconds or so. |
Unlocking the FlashPro from the vehicle will also clear the security password.
