Vehicle Locking
A FlashPro may only be used on one vehicle at a time, where it is locked to the vehicle's ECU.  If the FlashPro is swapped to another vehicle or sold, then the FlashPro must be unlocked from the old vehicle before being transferred to the new vehicle.
If the vehicle is replaced then the FlashPro should be unlocked from the old ECU before the ECU is removed from the vehicle.  If the ECU is damaged then the old ECU and FlashPro must be sent to Hondata for unlocking.
The FlashPro is not designed to be switched between multiple vehicles on a regular basis.  Separate FlashPros for each vehicle should be purchased for this situation.
