The S300 can output CAN packets for datalogging or other use. This is available from the CANL and CANH pins on the S300 digital connector.
Format: 11 bit, 250 kbps, big-endian
Speed: 100 Hz, cycling through the packets
The S300 does not have a CAN termination resistor.
MoTeC SDL/ADL: 500 kbps, same packet format
ID
Description
Data
Conversion
0x660
Rpm, speed, gear
Rpm (16 bits)
Speed (16 bits)
Gear (8 bits)
Voltage (8 bits)
rpm
speed (kph)
gear
volt / 10 (volts)
0x661
Temperatures
IAT (16 bits)
ECT (16 bits)
air temp (ºC)
coolant temp (ºC)
0x662
Throttle position, manifold pressure
TPS (16 bits)
MAP (16 bits)
tps (%)
pressure / 10 (kPa)
0x663
Injector duration, ignition advance
INJ (16 bits)
IGN (16 bits)
inj / 1000 (ms)
ignition advance (º) signed value
0x664
Lambda
Equivalence ratio (16 bits)Lambda (16 bits)
32768/ ratio (lambda)
32768/ lambda (lambda)
0x665
Knock
Knock count (16 bits)
unused on the S300
0x666
Cam angle
Target cam angle (16 bits)
Actual cam angle (16 bits)
unused on the S300
unused on the S300
ID
Description
Data
Conversion
0x667
Analog inputs 0-3
Analog0 (16 bits)
Analog1 (16 bits)
Analog2 (16 bits)
Analog3 (16 bits)
voltage (volts) x 819.2
0x668
Analog inputs 4-7
Analog4 (16 bits)
Analog5 (16 bits)
Analog6 (16 bits)
Analog7 (16 bits)
0x669
Ethanol content
Frequency (8 bits)
Duty (8 bits)
Content (8 bits)
frequency (Hz)
duty * 2.56 (%)
ethanol content (%)
