Digital Input / Output Wiring
The s300 v3 digital connector has 6 pins. In order to match the wiring connect, remove the outermost wires (black and red) from the connector..
S300v3(white) digital input / output wiring
Pin
Wire Color
Meaning
CAN H
White
CAN high
CAN L
Blue
CAN low
RS232 Rx
Yellow
RS232 serial receive
RS232 Tx
Green
RS232 serial transmit
TTL In-
Brown
TTL serial input (inverted)
TTL In+
Grey
TTL serial input (normal)
TTL Out
Purple
TTL serial output
Ground
Black
