Plugins and Scripting |
Introduction SManager can run scripts to change calibration values and automate functions using use the Lua language https://www.lua.org/. Scripts are packaged in the form of a Plugins.
Plugins Plugins can either by run from the Plugin menu or can run in response to events (like loading a datalog). A plugin can do things like update calibration parameters/tables or analyze datalogs.
Installing a Plugin
Also see Writing a plugin
Security Plugins can change any parameter or table in a calibration. Only install and run plugins from trusted sources.
Plugin Graphics Work in progress. Unsupported.
Plugin Debugger Work in progress. Unsupported.
