With Bluetooth error codes are mapped from OBDI to OBDII, as Bluetooth apps do not use Honda specific codes.
Error Code
OBDII
Oxygen sensor A
P0130
Oxygen sensor B
P0150
MAP sensor
P0105
Crank angle sensor
P0335
Water temperature sensor
P0106
Throttle position sensor
P0123
TDC sensor
P1362
CYL sensor
P0340
Air temperature sensor
P0113
Overheating
P0217
EGR
P0403
PA
P1106
Idle control
P0505
Fuel injectors
P0200
Speed sensor
P0500
ELD
P1298
VTEC spool
P2649
VTEC pressure
P2647
Knock sensor
P0325
Knock sensor
P1324
O2 sensor heater
P0135
Fuel supply system
P0169
