Script Reference |
Objects
All index values start at 1 in order to make Lua for loops simpler. Functions (vs constant table members) are designated by the use of parentheses () after the name.
Application String app The application name (SManager) String version The SManager version number. Integer build The SManager build number (normally 4 digits) Boolean bit64 True if the SManager is the 64-bit version. String compiledate eg Thursday, March 7, 2018 8:00 AM String locale The two character locale (country code). String os eg Windows 10 Professional (build 18363), 64-bit
Device String name S300 Boolean connected() True if the S300 is plugged into the computer via USB or Bluetooth Integer hardware() The S300 hardware version Integer serial() The S300 serial number Boolean isdatalogging() True if the S300 is datalogging Boolean isrecording() True if the S300 is recording Integer datalogcount() The number of datalogs stored on the S300 Function datalogdownload(index) Not implemented
ECU Boolean ignitionon() True of the vehicle ignition is switched on Function startdatalogging() Start datalogging Function stopdatalogging() Stop datalogging Function startrecording() Start recording Function stoprecording() Stop recording
Sensor String name() The sensor name String abbreviation() The abbreviated sensor name String description() The sensor description Number min() The minimum value for display. Number max() The maximum value for display. Integer type() The unit type of the sensor as a number. Use Hondata.TypeName from constants.lua to convert to a type name. Integer unit() The unit of the sensor as a number. Use Hondata.UnitName from constants.lua to convert to a unit name or Hondata.UnitUnit from constants.lua to convert to an abbreviated unit name. Number live() The live (realtime) value of the sensor from the ECU.
SensorList Integer count() Number of sensors Sensor sensor(index) Returns the Sensor at an index. The SensorList subscript operator ([]) can also be used to return the sensor, either using a numerical index or the sensor abbreviated name.
Datalog String filename() Filename of datalog Integer framecount() Number of frames in datalog Number length() Length of datalog in seconds Number timestamp(frame) Timestamp in second at a frame number Integer framenumber(timestamp) Frame number at a timestamp in seconds Number value(Sensor, frame) Datalog value by sensor and frame number Number sensorcount() Number of sensor used in this datalog Sensor sensor(index) Returns the Sensor at an index
DatalogManager Integer count() Number of datalogs current loaded into SManager Datalog datalog(index) Returns a Datalog object for the datalog at index index
Table String name() Table name String valuename() Table unit name Integer dimensions() Number of table dimensions (0-3). Integer length() Number of values in table Integer size() Table size in bytes Integer type() The unit type of the sensor as a number. Use Hondata.TypeName from constants.lua to convert to a type name. Integer unit() The unit of the table as a number. Use Hondata.UnitName from constants.lua to convert to a unit name or Hondata.UnitUnit from constants.lua to convert to an abbreviated unit name. Boolean readonly() True if the table is read only. Number GetValue(index, index, index) Get the table value. Indexes start at 1. Function SetValue(value, index, index, index) Set the table value. Indexes start at 1.
Calibration Boolean loaded() True if a calibration is loaded String filename() Calibration filename function update() Updates the calibration with changes made to tables Integer tablecount() Number if tables in the Calibration Table table(index) Returns the table at an index
ErrorCode Integer code() The DTC error code number String description() The DTC description
ErrorCodeList Integer count() Number of DTCs clear() Clear DTCs ErrorCode code(index) Returns the ErrorCode at an index
Event Callbacks OnCalibrationNew(calibration) A new calibration has been created. OnCalibrationOpen(calibration) A calibration has been opened OnCalibrationClose(calibration) The calibration is in the process of being closed. OnDatalogOpen(datalog) A datalog has been opened. OnDatalogClose(datalog) The datalog is in the process of being closed. OnDatalogStart() Datalogging has been started from SManager OnDatalogStop() Datalogging has been stopped from SManager
Functions String InputQuery(caption, prompt, default) Shows a dialog where the user can input a string. This function returns the entered string or nil if canceled. ShowMessage(message) Shows a MessageBox with the given message.
Utilities To use utilities add require("utilities") to the top of your script. table_print(table) Dumps the Lua table to the log file. Note that
Constants Constants are stored in the Hondata table which is available as a global. Integer Type Constants for value types eg AirFuelRatio, Temperature, Pressure, Voltage String TypeName English language names for the value types. Integer Unit Constants for unit types eg Lambda, DegreesC, Bar, Volts String UnitName English language name for the unit types String UnitUnit English language name for the unit units eg :1, %, bar, v Integer TableKind Constants for table kinds (parameter, index, table etc) String TableKindName English language name for table kinds |
