All serial output formats use the same output packet.
Serial Specifications
| • | 115,200 bps (software selectable), 8 data, 1 stop, no parity |
| • | Packets are sent at 10Hz |
Packet Description
| • | Words are send with most significant byte first. |
| • | The checksum is calculated as the byte sum of the packet subtracted from 0xFF. The byte sum of the packet, including the checksum, should be 0xFF. |
Byte
Contents
0
Identification byte (0x69)
1
Speed (kph, LSB = 1 kph)
2-3
Rpm (LSB = 0.25 rpm)
4
Gear (0 - 6)
5
ECT (degrees Celsius + 40, LSB 1 deg)
6
IAT (degrees Celsius + 40, LSB 1 deg)
7
Battery voltage (volts, LSB = 0.1V)
8
TPS (0% = 0x15, 100% = 0xE5)
9-10
MAP (mbar, LSB = 1 mbar)
11-12
Injector duration
13
Ignition timing (degs + 0x80, LSB = 0.5 deg)
14
Output bit field
15
Input bit field
16
Unused
17-18
Lambda (0x8000 = 1.00, LSB = 1/0x8000 lambda)
19-20
Knock count (knocks since power on, LSB = 1 knock)
21
Checksum
Output bitfield
Bit
Meaning
0
Unused
1
Brake switch
2
AC switch
3
AC clutch
4
Unused
5
EPS/PSP
6
Fuel pump
7
Radiator fan
Input bitfield
Bit
Meaning
0
VTEC oil pressure
1
VTEC solenoid #1
2
VTEC solenoid #2
3
MIL
4
Nitrous 1 arm
5
Nitrous 2 arm
6
Nitrous 1 active
7
Nitrous 2 active
