The S300 V3 can output Rs232 serial information to the AiM MXL dash range.
Setup
| • | Wire the RS232TX pin on the s300 to the RS232RX pin on the AiM dash. |
| • | In SManager / Parameters / Digital Input / Output select 'AiM MXL'. |
| • | Upload the calibration to the ECU. |
| • | In the AiM 'RaceStudio' configuration software select 'Hondata' as the ECU manufacturer and 'KPro' as the ECU Model. |
Note that you do not need the AiM KPro converter (part number X05EFIHKPRO). The s300 can drive the dash directly.
See Serial Output Format
