The S300 V3 can output Rs232 serial information to the RacePak IQ3 dash/logger. RacePak part #230-VM-EFIHOND is needed to convert that ECU signal to V-Net.
Setup
| • | Wire the TTL Out pin on the s300 to the RacePak KPro converter (it only has 1 wire). |
| • | In SManager / Parameters / Digital Input / Output select 'RacePak IQ3'. |
| • | Upload the calibration to the ECU. |
| • | In the RacePak Datalink software the converter should be detected and channels assigned automatically. |
See Serial Output Format
