Hondata s300 Programmable ECU Guide
Contents
| Index
- 3 -
3 BAR MAP Sensor
- A -
A/C clutch
A/C switch
Adjust Selected Values
AFCMD
AiM
Air Temperature Compensation
Air Water Compensation
Analog
Analog Input
Atmospheric pressure sensor
Autotune
- B -
Battery voltage
Boost Control
Boost Control ECU Preparation
Boost Control Parameters
Boost Control Solenoid
Boost Parameters
Brake switch
- C -
Calibrations
CAN
Changed Value
Check For Updates
Clear DTCs
Closed Loop Advanced Parameters
Closed Loop Parameters
Contents
Create Forced Induction Tables
- D -
Datalogging
Datalogging Parameters
Digital
Display Window
Download Calibration
DUTY
- E -
E85
ECT
ECU Connectors
ECU Socketing
ECU Troubleshooting
Error Codes
Error Codes Window
Export Datalog
Export Movie
- F -
fuel trim
Fuel Trim Parameters
Full Throttle Shift Parameters
- G -
Gear Compensation Parameters
General Settings
Graph Templates Window
Graph Window
- I -
IAT
Idle Parameters
Idle Speed
IGN
INJ
Installation
Installing the ECU in the Vehicle
Installing USB Drivers
ITBs
- K -
K Level
Knock level
Knock retard
- L -
Lambda Overlay
Language
Launch Control Parameters
Lean Protection
Long term fuel trim
- M -
Main Window
MAP
MAP Parameters
Map Sensor Installation
Microsoft Bluetooth stack
Misc Parameters
MoTeC
- N -
New Calibration
Nitrous Parameters
Notes Parameters
- O -
On-board Datalogging
Overheating Protection
Overrun
- P -
Parameters Window
- R -
RacePak
Rev Limit Parameters
RPM
RS232
- S -
S300 Window
secondary injectors
Secondary Tables
Sensor Overlay
Sensor Setup
Sensors Window
Serial
Set Ignition Timing
Settings
Shift Light
Short term fuel trim
Switch Inputs
- T -
Table Index
Table Window
Target Lambda
Throttle Tip-In Compensation
TPS
Traction Control
Translation
TTL
Tuning Fuel Tables
Tuning Ignition Tables
Tuning ITBs
Tuning Troubleshooting
Tuning VTEC
- U -
Undo History
Unit Settings
Upgrading Calibrations
Upgrading V3 Files
Upload Calibration
Uploading Calibrations
USB
USB driver
- V -
Vault Terms Of Service
VSS
VTEC Parameters
- W -
Water Temperature Compensation
What's New
Wideband Lambda
Windows Vista
Windows XP
