Introduction
Contents
s300
s300 v2
s300 v3
Differences between the s100, s200 and s300
Differences between the S300 and S300J
S300 Identification
What's new in this version
Copyright
Software License Agreement
Privacy
s300 Installation
Installation Overview
Installing the ECU in the Vehicle
Installing USB drivers (XP)
Installing USB Drivers (Vista / 7 / 8 / 10 / 11)
s300 ECU Socketing
Calibrations
Introduction to Calibrations
Uploading Calibrations to the ECU
Upgrading Calibration Files
Upgrading V3 Files
Datalogging
Introduction to datalogging
On Board Datalogging
Sensor Setup
Export Datalog
Export Movie
Tuning your vehicle
Tuning fuel tables
Tuning ignition tables
Tuning the VTEC point
Tuning ITBs
Setting the Idle Speed
Windows
Settings
General Settings
Units Settings
Display Settings
Sensor Overlay Settings
Target Lambda Settings
Analog Input Settings
Autotune Settings
Datalog Settings
Main Window
Undo History
New Calibration
Create Forced Induction Tables
Adjust Selected Values
Table Window
Lambda Overlay
Changing Table Index Values
Changed Value Highlight
Graph Window
Datalog Comments
Graph Templates
Parameters Window
Analog Input Parameters
Analog Wideband
Analog Pressure
Analog Temperature
Analog Wiring
Boost Control
Boost Control ECU Preparation
Boost Control Solenoid Installation
Boost Control Parameters
Boost Control Example Graphs
Boost Parameters
Closed Loop Parameters
Closed Loop Advanced Parameters
Digital Input Parameters
Digital Input / Output Wiring
Serial Formats
Serial Output Format
AiM Dash Output
RacePak Dash Output
MoTeC Dash Output
CAN Output
Flex Fuel
Fuel Compensation Parameters
Fuel Injector Parameters
Staged Fuel Injection
Fuel Trim Parameters
Full Throttle Shift Parameters
Gear Compensation Parameters
Idle Parameters
Ignition Compensation Parameters
Launch Control Parameters
MAP Parameters
MAP Scalar and Offset
Adding a MAP Sensor
Misc Parameters
Nitrous Parameters
Notes Parameters
On Board Datalogging Parameters
Protection Parameters
Advanced Protection
Rev Limit Parameters
Secondary Tables
Security Parameters
Shift Light Parameters
Traction Control
TPS Parameters
TPS Ignition Parameters
VTEC Parameters
Sensor Window
Display Window
Error Codes Window
S300 Window
Security
Reset Password
Shortcuts Window
Commands
Email Files
Compare Calibrations
Upload
Test Upload
Download
Erase ECU
Set Ignition Timing
Test Outputs
Clear DTCs
Check for Updates
Send feedback to Hondata
Quick Support
Hondata Vault
Vault Terms of Service
Using Vault
Registration & Login
Storing & Retrieving Files
Operations
Calibration Details
Searching Vault
Reference
Sensors
Engine Sensors
RPM
MAP
TPS
IAT
ECT
PA
Engine Outputs
INJ
DUTY
IGN
Vehicle
VSS
Gear
BAT
ELD
Closed loop
O2
S TRIM
L TRIM
AF
CL
O2Heat
LVolt
Knock
K Retard
K Level
ECU
REVL
IGNC
BstC
Lnch.R
Lnch.C
Shft.C
Data
Frame
IAT.c
ECT.c
PWM
Sec Table
Sec Inj
Inputs
BKSW
ACSW
PSP
VTP
SCS
Outputs
MIL
ACCL
VTS
Fuel
PCS
IAB
FANC
ALTC
A10
Nitrous
N1Arm
N1On
N2Arm
N2On
N3Arm
N3On
Analog inputs
Analog Input 1
Analog Input 2
AN0-AN7
Eth %
Fuel T
Digital inputs
DI0-DI7
Traction control
ECU Wiring
ECU Connectors
Error Codes
Switch Inputs
Vista Virtualization
DDE Server
Language
Bluetooth
Bluetooth Technical Details
Bluetooth Options
Connecting with a Laptop
Bluetooth Error Code Mapping
Plugins and Scripting
Writing a plugin
Script Reference
Troubleshooting
USB Troubleshooting
Manual USB Driver Installation (Windows XP)
Manual USB Driver Installation (Windows Vista / 7 / 8)
ECU troubleshooting
Tuning troubleshooting
Error Reporting
© 2024 Hondata, Inc.
