Introduction
Contents
What's new in this version
Specifications
Requirements
Copyright
Software License Agreement
Privacy
The FlashPro
Installation
Installation Warnings
Installing FlashProManager Software
Installing USB Drivers (Windows XP)
Installing USB Drivers (Windows Vista / 7 / 8 / 10 / 11)
Connecting FlashPro to your vehicle
Wideband lambda interface
Vehicle Locking
Locking to a Vehicle
Unlocking from a vehicle
Dealer FlashPro
Master Dealer FlashPro
Calibrations
Modifications
Quick Modifications
Programming Your ECU
Opening a Calibration
Uploading a Calibration
Downloading a Calibration
ECU Recovery Mode
Maintenance Minder
Live Tuning
Instant Live Tuning
Tuning Your Vehicle
Fuel Tuning
Tuning mass flow fuel
Tuning AFM Flow
Tuning speed/density fuel
Part throttle fuel tuning (MAP)
Tuning Starting Fuel
Tuning ignition tables
VTC tuning
VTEC point tuning
VTEC crossover tuning
AFM removal
Table indexes
Knock control tables
Individual cylinder ignition
Lambda Correction
Rev hang
Cruise Control Lambda Display
Active Tuning
Active Fuel Tuning parameters
Active AFM Tuning
Multi-tune
Datalogging
Laptop datalogging
On board datalogging
Sensor Setup
Graphing
Security
Owner Information
Security Password
Reset Password
Purchasing a Used FlashPro
Hondata Vault
Vault Terms of Service
Using Vault
Registration & Login
Storing & Retrieving Files
Operations
Calibration Details
Searching Vault
Reference
Shortcut keys
Windows
Settings
General Settings
Unit Settings
Display Settings
Lambda Overlay Settings
Sensor Overlay Settings
Datalog Settings
Autotune Settings
Main Window
Options
Language
Table Window
Changing table indexes
Proportional Tracing
Changed Value Highlight
Sensor Overlay
Calibration Window
Calibration parameters
Fuel parameters
Fuel Pump
Ignition parameters
VTEC parameters
VTC parameters
Closed loop parameters
Knock control parameters
Rev limit parameters
Launch Control (Adjustable)
Hondata Mode
Sensor parameters
Idle parameters
Throttle parameters
Boost Control Parameters
Boost Control Installation
Boost Control Example Graphs
Turbocharger Parameters
Torque parameters
Misc parameters
Ethanol Parameters
Methanol Injection
Traction Control Parameters
Traction Control (Hardware)
Traction Control (Software)
Graph Window
Datalog Comments
Advanced Graphs
Graph Templates
Sensor Window
Display Window
Error Codes Window
FlashPro Window
EPA/CARB Restriction
OBDII Diagnostics
Shortcuts Window
Dealer FlashPro
G Force Window
Commands
Email Files
Check For Updates
Check Internet Connection
Send feedback to Hondata
Update Boot Firmware
Compare Calibration
Quick Support
Sensors
RPM
VSS
Gear
MAP
BP
AIRC
WG
TPedal
TPlate
AFM.v
AFM
INJ
Duty
DIFP
IGN
IAT
IAT2
ECT
CAM
CAMCMD
EXCAM
EXCAMCMD
AF
S.TRIM
L.TRIM
TRIM
Fuel Status
K.Level
K.Retard
K.Control
Ign.Limit
K.Count
PA
BAT
VTS
Eco
Fuel Used
Frame
BC Duty
ECU Connectors
S2000 EGRL Input
Error Reporting
DDE Server
Vehicle Specific Notes
Accord 2004-2010
Accord 2013-2015
Accord 2018+
Civic R18 2006-2015
Civic Si 2006-2011
Civic Si 2012-2015
Civic Si 2017-
Turbocharger Notes
Civic Type R 2007-2011
Civic Type R 2015-2017
Civic Type R 2017-2021
Tuning Notes
VE correction
FK2/FK8/FL5 Starting Fuel
FK8 Anti Lag
FK8 Flex Fuel
Jailbreak
High pressure fuel pump control
FK8 Readiness
Pops and bangs FK8
Civic Type R 2023+
Tuning Notes
Jailbreak
FL5 Advanced Tables
Pops and bangs (FL5/DE5)
Civic 1.5T 2016+
Tuning Notes
Pops and bangs 1.5T
CRZ 2011-2013
Fit 2007-2008
RDX 2007-2012
S2000 2006-2008
TL 2007-2008
TSX 2004-2014
Bosch Torque Model
CAN Bridge
CAN Boost
Plugins and Scripting
Writing a plugin
Script Reference
Frequently asked questions
Updating Calibrations
Bluetooth
Bluetooth Technical Details
Bluetooth Options
Bluetooth Vehicle Pairing
Connecting with a Laptop
Bluetooth Test Mode
© 2026 Hondata, Inc.
